Old 12-04-2003, 05:40 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Default U-Joint Grease - What Nozzle or Adaptor??
Good Question for you Old Timer ERA Guys....
While crawling around under #375, while the Cobra was on Jack Stands, I did notice grease nipples on each end of my Jaguar drive shaft Universal Joints. I whipped out the trusty grease gun but the nozzle at the tip of my grease gun just would not fit onto the fitting as there was not enough clearance.
So what is the trick to get these fittings greased?
Do you use some sort of needle adaptor or what?
Thanks in Advance.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
