Hi CCOMT,
Here's one, it's even shown on an E-M, just send me $500 and it's yours
http://www.cobraaccessories.com/ffhome.html
-Jon
P.S. I put one of these on my E-M and it is an easy install as long as you already have the stock E-M roll bar mounts welded on your frame. You will need the bolt on crossmember if you did not get that from E-M. I built mine from scratch and there is not much to it. You will also have to do some welding at the mount points in addition to tig welding the rear brace to the hoop.
