trany question
You will need to trim off the aluminum on the underside of the tranny so it clears the 4 inch round frame tubing. 5 minutes with a grinder or sawsall. Also I believe the tremec is longer so the drive shaft will need to be shortened. The splines on the propellor shaft are the same. I also shimmed my tranny up 1/2 inch and installed adjustable upper control arms to get a nice pinion angle so no binding occurs when 2 people are riding ion the car and you hit a sudden bump.
