Old 12-07-2003, 04:00 PM
Sean Teague Sean Teague is offline
Static compression is not the only thing to look at when determining what is streetable. You have to look at the valve events of the cam and see how much overlap there is as well. A cam big enough for a 408 should have at least some overlap which will bleed off some of that 10.5:1 compression. You'll have to take that into account as well.
FFR 4447 with DOHC power in the works
