Desktop Dyno please
351W (standard bore & stroke), 9.6 compression with AFR 185 heads (61cc with 2.02 valves) Holley 750 DP, cam has following specs: Duration advertised 296/306, at .050: 236/246, lift - .520 / .538, 1.6 rockers' 36 degrees total timing. I want to compare a Vic Jr. intake to a Air Gap RPM intake on this combo. Very curious to see what pops out. I know the Vic will make more top end power and the RPM will make low end torque, but I want to evaluate the area beneath the curve. Myabe post the graph if possible. Thanks very much in advance for any takers.
