Originally posted by John Poling
Mike Murphy,
What manufacturers' fan and model number are you using in the picture above? Also, Did you fab the mounting brakets or are they purchased from somewhere?
Thank you.
John
Hi John,
I found the box. The Company is ICE but it says on the packaging that the fan was made by a company called UniPoint.
The part number is 07-41612K
According to the graph on the packaging the fan pushes 2800CFM or if you flip the blade over and change the polarity it will pull 2500CFM. I've got mine set up in pull mode.
