On the HYD T O Bearing, I would bet it was never measured correctly for one and or it was never installed correctly. You MUST secure the two lines to keep them away from the rotating pressure plate and flywheel. I would take the HTO bearing over a slave cylinder on the FE engine every time.
Eliminator
