Old 12-09-2003, 03:36 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
I shall go out and measure it tonite and let you know. I am running a Holley 850 Double Pumper and the manifold is an aluminum Sidewinder.
Just got back in from measuring....
The filter is 2.5" high. It sits on a custom built lower platform.
With the K&N on and the Xstream on there is 3/8" clearance on the passenger side and 1/2" on the drivers side. I used modeling clay to do the measurements. These are the closest measurments that are towards the outside edges of the filter (not front or back) as the air scoop comes down on the edges.
The filter is indeed a 9" in diameter.
Hope this helps. I suspect the custom lower filter platform may have some play here?
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
