Fitting in tight quarters is most important
Subtle differences in how the adjustable starters fit make ALL the difference (each pivots on the base to some extent).
The CVR starter for the FE (available at Jegs) allows maximum rotation points to keep the wiring out of the headers. The FE newsgroup recommended this one and it fits much better than the ohter two (2) major brands I had tried.
Life and power are unknow, it works and FITS GREAT! Darn important in tight quarters.
CVR Protorque Racing Starters
171-5049 Ford FE $199.99
Ad says: These units are completely sealed with rubber ''O'' rings and the solenoid is encased in a heat-resistant aluminum housing for those close-header applications.
