Old 12-10-2003, 07:21 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
If you do not have an armature draging from heat expansion in starter (starter is OK ). One very easy way to start a high compression hot engine is to FLOOD the engine before hitting the starter button. If it is bumping against starter or firing a hole or two before starter gains enough RPM, help it out by pumping pedal 1 or 2 times. This wets the plugs a bit and allows it to spin over and gain starting RPM, this will then quickly dry the plugs and light right up.
This is the only way I could start my blown motors before all these gear reduction starters became available . Have fun.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
