Thanks Niles,
I finally go it figured out. Your a correct. Got my tire size/rear end ratio and bought the right gear. It is spot on.
Thanks for the info. Still have a problem with the needle bouncing around 10 mph, but I am going to re-lube with white grease and see what happens. I don't have any kinks in the cable. I read somewhere the reverse drive could be a little dry and also it takes some time to get the plastic gears set in.
Any comments?
Mark
