Old 12-14-2003, 10:51 PM
,,,,had the steering wheel, broke it. Slamming it from lock to lock took it out,
I'm Professional league. All cars and tracks are unlocked. I've placed first in 95% of the races. As you get up there the competition gets really fierce. You CANNOT win unless you set your car up for correctly for each track. Gearing is the most important, followed by the suspension settings. Proffesional league will FORCE tire wear, you can't turn it off. So, get used to "saving your tires" and running a harder compound. Set your gear ratio to max rpm at the end of the fastest part of the track. Keep your first three gears low to pull hard out of the corners. 4th and 5th is where the big jump in ratio's come in.
The further you get, the more REAL it becomes!
Ernie
