Old 12-14-2003, 11:55 PM
Ant Ant is offline
Default 31 spline parts
Ron61,
I am going to run with my 28spline setup with the H/D Eaton posi and Romac axles, but am going to accummulate parts so I can uprate to 31spline later!
What was necessary to uprate your rearend to 31spline, apart from Eaton having a 31spline sidegear , and I assume the Upright/splindle is same for all axles!
CV Joints
Axles
outer splined wheel bolt flange, that goes into upright bearings.
Probably to cut a long story short its everything apart from the alloy Upright, and wheel bearings?
Suggestions on parts availability, I suppose most wreckers have em?
A J. Newton
The 1960's rocked!
