What Type Hose Can I Use????
I relocated my fuel cell and need to use a piece if hose to connect the tank inlet to the Le Mans gas cap. I was told "radiator hose" will disintegrate (wheres my thesaurus) with fuel in it. Not in particle form but in liquid form making it past my fuel filter and clogging my fuel injectors. If this is true, what type/s of hose are available? I need on with 2 1/4 ID at on end with a 1 1/2 ID at the other end. This hose must have a 90 degree bend in the middle with approx. 3" tangents. I was thinking of dipping the radiator hose into the rubber tool caoting that you can buy. That stuff is suppose to resist gasoline. anybody got an opinion or suggestion?
Thanks
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
