  #21 (permalink)
Old 12-16-2003, 04:31 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Ok, I did the Driven Gear change. It was not too hard at all. Actually, the hardest part was figguring out how to get the bolt out as there is not too much space in the tunnel to work on this. I used a 7/16 socket on a universal joint on an extension. That did it nicely. Once the bolt that holds the retainer was out and the retainer moved away, then I pulled gently and tugged on the cable to no avail.
So after a cup o coffee I just got in there with gloves on and gave it one nice firm pull and it popped out. Surface tension was hoding it in. The gear pulled off and the new one was in jiffy quick.
Thanks for all the advice and guidance Guys.
Cheers.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
