Old 12-18-2003, 07:31 AM
Roscoe's Avatar
Roscoe Roscoe is offline
Chaplin,
I don't think you can get simpler than a t/o. When I was building my Cobra and got to the point I had to think about what I was going to do I found the t/o to be the simplist. Why? Well first I had to make a bracket for the fork and then the pedal with the cable adjuster then run a cable and then have to deal with adjusting the cable due to stretch.
I mean I just installed the bearing and bled the lines with a small amount of adjusting I was finished. I've never touched it since other than to drain and replace with fresh fluid.
Can' t be simpler than that,
Roscoe
Roscoe
