Old 12-18-2003, 08:47 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Roscoe-
If I had fabricate brackets and such I can see the benefit of using a hydraulic t/o. But I think the set up on my car is simpler than a hydraulic. I just have a hydraulic slave cylinder bolted to the block which activates a stock clutch fork. I don't have to mess with cables or worry about the hydraulic t/o leaking, etc. But I see your point.
How about generic advantages/disadvantages of hydraulic v. manual t/o bearings? For instance, if you could use either with relative ease (i.e., no fabrication was required to use either system), what are the pros/cons of each setup?
Replica is not a dirty word.
