Thread: rolling chassis
Old 12-18-2003, 12:46 PM
BCDD1288 BCDD1288 is offline
Cobra Make, Engine: LS 427, Small block Chevy
The engine is .030 over 350, 4 bolt main, "X" rods, balanced, billet harmonic balancer, hypereutectic pistons, 2.02 heads, stainless steel valves, port matched to intake, Crane 1.6 roller rockers, Edlebrock Performer RPM intake, Edlebrock valve covers,
Holley carb- 600cfm electric choke, Centerforce flywheel, trans is a T-56 6 speed out '97 Z-28, mild cam-has a nice little lope at idle.
Eagle Alladin coilovers, 4 link suspension in the rear, upper and lower A-arms in front, maual rack and pinion (Flaming River), Ididit steering colume, tilt, Grant steering wheel, 5 point harness both seats, Moroso water pump, Tilton master cylinders, large bore clutch master so pedal travel is minimal, Proform HEI with billet shaft, Accel race wires, harness is from Painless, Interstate battery in trunk, 4 wheel disc brakes, Lokar E-brake lever.
