Old 12-18-2003, 01:12 PM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Rick - don't know what's available in the 'states, but here, you can get several "grades" of UJ for the jag rear end. They are all, so far as I know, std Hardy-Spicer items, but there definitely are upgrade items over stock available. That's what went into my car, anyway. I stopped upgrading just short of beefier yokes.
Tip - when fitting the outboard ones, make sure you fit an angled grease nipple facing inboard, so that you can get a grease gun onto them, A standard "vertical" nipple makes this impossible as the UJ is shrouded by the hub carrier casting once fitted.
HTH
Wilf
Wilf
