Old 12-18-2003, 09:33 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Default 2 Post Lift/Chassis alignment
David
When I was out at your shop the other day.... and we were talking .... the subject of using a 2 post lift came up.....
The question I had was how do you do Alignment of the wheels and tires off of the frame rails if the suspension is not loaded..
How do you check the Camber ....or Toe.... or Castor on a 2 Post lift....
I do like the way everything is out of your way on a 2 post lift.... just didn't understand your statement that we have a special way to do it.....
Can you discuss how you do it.
Thanks
Morris
