Old 12-19-2003, 01:23 PM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Rick....definately think you got something out of whack....squirter should not need to be any larger than low to mid 30's....i'm running 1050 dominator and only need 32 squirts...actually with the 50cc pump you only pick up 2cc of gas over the 30cc pump...pumps are rated by using 10 pumps...10 pumps will give you 30 or 50 cc....take the 20 difference and divide by 10 gives you 2cc per stroke.....to bad the weather isn't a little warmer...say 45 or 50 degrees more....i'd give you a hand....
Jack
XSSIVE .....
