What Would I Use For A Block Plate?
Lakewood has another bellhousing....one that's not SFI approved, but is made of the same 1/4" thick steel, and is the same shape as their blowproof bellhousing. It says in the description that it is not intended for use with a block plate...If not, then what do you use to cover the flywheel/clutch, and bolt the starter to?
