Old 12-22-2003, 02:22 AM
Cobranut Cobranut is offline
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Jack,
What you're referring to I've always heard called "motor plate".
What he's talking about is the plate between the flywheel and block, sandwiched between the block and bellhousing.
My guess would be that this bellhousing depth does not compensate for the block plates thickness.
You'd probably have to fabricate a shield which would mount to the flange at the bottom only to cover the flywheel.
David
