  #28 (permalink)
Old 12-23-2003, 11:51 AM
BEB BEB is offline
Cobra Make, Engine: AK 427 - 409ci SBC, Getrag 5 sp.box.
Thanks Guys;
Ist reply to Niles:
It is definitely a lean bog as I have a air/fuel analyser fitted in the form of a lambda sensor so I can see it momentarily leaning off.
To mr0077:
I may well have to go up 1 or 2 primary jets to compensate. Also, I have checked the accelerator pump arm gap at wide open throttle and it is .015". However, if the arm doesn't move immediately when opening the throttle does it mean I should try a different colour cam, and if so, which one as the current one is Green in the number 1 position.
To Rick:
I'm fairly certain the throttle plates are set correct (the primary one definitely is). The cam is a relatively mild Comp Cams 268 hydraulic and the idle vacuum is around 15/16Hg. The idle is nice and smooth.
I think the problem is caused by the accelerator pump not getting fuel in soon enough. I'm running a Green cam at the moment so which one will give a "faster delivery"?
Your feedback is excellent and I'm very grateful to you all !!!
