Originally posted by BEB
Thanks Guys;
However, if the arm doesn't move immediately when opening the throttle does it mean I should try a different colour cam, and if so, which one as the current one is Green in the number 1 position.
The arm
must move the instanst you begin to open the throttle or you will get a stumble/hesitation. Adjust it so that there is little or no clearance when the throttle is closed. You need the pump to squirt as soon as you begin to open the throttle. But make sure you have the required clearance at WOT.
