carb update...I rejetted the carb (770 street avenger double pumper) to facotry jets and factory power valve...runs better! I have a very slight off idle hesitation and I picked up 2 pump squirters..I am replacing the 28's with 31's and I think this will cure my hesitation. I noticed by revving it up under the hood if I manually stroke the accelerator pump there is no hesitation so I just need more fuel. I guess thats common with big cam and single plane intake. Will update you when its done. Thanks for the input..
