Old 12-24-2003, 07:48 AM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Default Re: Let's turn up the Heat in here
Originally posted by The Dreamer
Being the kind of person who can't leave well enough alone, I want to put a heater in 258 to extend my driving season. Fall in VA can be chilly. Who has installed a heater and which one did you use? My plan is to install a tonneau cover and insulate the Dickens out of the cockpit.r
There's a piece of aluminum that's mounted on the top front of the tunnel that's wedged between the dash support tubes and the firewall. It's a tight fitting piece when carpeted so I never screwed it to the tunnel. You can crack it open a couple of inches and that exposes the engine compartment which in turn will transfer engine heat to the cockpit. While driving at speed, it does throw out some significant heat.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
