I'll bet it's not coming from the seam between the water pump/front cover. If you look at the underside of the water pump there's a small hole about 3/16" in diameter. Often a water pump will weep from that hole. That's an indication that the water pump seal is going bad (the seal between the water and the bearing on the shaft).
Chris
