  #37 (permalink)
Old 12-24-2003, 01:20 PM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
I should be interested to know how those "materlube" units work. The Accusump uses a piston inside the cylinder to separate the oil/air.
If you have to mount the other unit vertically - does this infer no piston? I would be a tad worried about the oil foaming due to vibration if the unit were mounted on the engine block in that case.
Wilf
