Old 12-26-2003, 02:23 PM
BlueRooster's Avatar
BlueRooster BlueRooster is offline
Cobra Make, Engine: SPF #623 460/4x2
I have the 385 block in mine. I dont think anything was altered to get it in. I have the aluminium CJ heads and the BT intake. I am having a bear of a time getting the two plugs out to change them on the drivers side closest to the firewall. I thought I would take out part of the steering column to give me more room, but it looks like more trouble than it is worth.
I switched over to the external hydraulic clutch and the fork ass'y is less than an inch from the brake lines on the frame rail. The way the engine spins it misses the lines but it is very close. I have a makeshift torque strap from the engine to the frame for now, but next year I would like something more permanent(with a heavy-duty turnbuckle) this is not something you can just buy and bolt-on, it has to be fabricated. This with better motor mounts ought to keep the engine more confined. My side pipes smacked the exit side hole so the torque strap is more of a nessesity than a cool add-on.
Dane
