Old 12-27-2003, 01:21 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Any 427 dipstick will work. The dipstick hole is not changed by changing pans. The hole you are looking at (small hole right side of the pan) Is a hold over from the Le Mans cars oil return line.
I'm not suggesting you shouldn't, couldn't or might not want to put a dipstick there. Most people just plug them permanantly or install a return line there.
You may want to fill your Aviaid pan to specified capacity and mark the current dipstick. Run the engine for a little while to purge the oil lines, fill the filter and then recheck the level. you may need to do this a few times to get the filter(s) completely full. recheck the level, replace the oil in the filter to the former level and make that the full line.
www.aviaid.com
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
