Thread: Dash Wiring
Old 12-27-2003, 04:06 PM
TC Cobra's Avatar
TC Cobra TC Cobra is offline
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Question Dash Wiring
Don,
Finishing the wiring on the dash and have a couple of questions:
**Headlight switch:
#171 to position 1
#141 to position 2
The switch I have (the one you use) is not the same as the illustration in the manual (big surprise, eh?). Mine has two common terminals in the middle and two above and two below. Where do #’s 171 & 141 go?
**I’ve wired the interior courtesy lights to a toggle switch. Do I need to do anything with #’s 178, 179 & 183? (Door switches and ground)
**What is the best source of power for my elect speedo?
**How do you hook-up the voltmeter?
Fingers are crossed hoping everything else is good and will work as expected.
Thanks!
Dwain
