Need Jag IRS help
Well, I just checked my left rear wheel, and I've got a bent hub flange. I measured 0.003" radial runout and 0.008" axial runout, at the outer edge of the wheel hub flange (just outside the lug studs). It is enough that you can see a slight wheel wobble while following the car.
This is a standard 1988 XJ6 hub/wheel flange assembly. Anyone replaced one of these? Is this something reasonably do-able or should I take it to a Jag mechanic?
I read the Jag manual and it looks do-able except for pressing on the bearing races, but there is a mention of setting the free play also. The best price I found for a hub flange is $189.90 ($211 list) at Moonlight Mechanic...ouch!
Thanks.
Ken
