Ken: I just replaced an inner bearing on my car a month ago. It was not a problem. I did go to the jag dealership and had the bearing pressed. the cost was 100.00 for the labor.
As far as the freeplay, there will be a spacer between the bearing
and the shaft. You should be ok. I was. The freeplay is 2 to 4
thousands. Your locking nut need to be tourqued to 100 ft lbs.
Good luck...Randy
