Old 12-28-2003, 08:03 PM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Default 428 with MSD or Other Problem. (Solved!)
Hello Everyone,
Well, I just got my 428 ready to fire this morning and I've had trouble ever since. I have gone though and checked the usual suspects. I have plenty of fuel, the firing order is correct, I've checked the timimg about six times and I still can't get this thing to run. The firing order is correct and I've verified that as well. The motor tries to fire like a few plugs are missing every time I try to start it. I checked the cap and rotor, coil and my Motorsport Distributor and they seem fine. The only thing I can think of is the MSD 6AL Box. It is wired as follows:
Big red wire to Positive power on Solenoid.
Small red wire to keyed power switch.
Black to ground.
Purple and Green wires to Purple and Orange from distributor.
White is not used.
I have checked the ground and its good. It comes very close to firing but doesn't. When I checked the plugs, some were wet with fuel some were carboned from ignition. I have never used a MSD ignition before and any help would be great. If there are any good testing procedures for this set-up, please let me know as well.
Thanks,
Mike
