Old 12-29-2003, 07:25 AM
CSCHWER CSCHWER is offline
Cobra Make, Engine: SPF 2682, Roush 427
I have a Protronic (GM) type dist. so I removed the module (4pin) and hooked the MSD supplied wires and connector to the connector on the end of the magnetic pickup in the dist.
The plastic clamps MSD supplied would not allow me to mount the connector using the bolts and mounting holes where the ign. module was mounted so I mounted the wires with 2 aluminium clips. I had the same problem you are describing so I just mounted the wires with 1 plastic clamp in the hole closest the exit. I'm thinking about just cutting off the connector on the mag. pickup and soldering the wires together.
Chet
