Thread: Dash Wiring
Old 12-29-2003, 08:16 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, on the back of the switch each lug is numbered 1 thru 6. Wire the switch as follows:
wire #171 to 3, jumper from 3 to 1
wire # 141 to 6
wire # 112 to both 2 and 5
The switch will be off in the center, down for parking lights, up for headlights and parking.
You can use gauge power #130 for the speedo.
The door switch wiring could be eliminated.
You can use the same power wire for the voltmeter #130, and a ground.
Don
