David,
You will have to speak with Dave about body mount and fit status. I know that the body was put on the chassis to check dash fit and for rollbar marking.
I think that Dave is waiting for the lining material that you requested for the underside of the body. (I have no clue where or what this material is, once again check with Dave.)
I have discussed a number of things about the build and chassis setup stuff with Dave that needs to be changed from your build. I am told that these are in process.
I know that the ride height blocks for your setup have been made and the setup struts.
It appears that I will do the the chassis setup myself. Sunday will be my first opportunity to do this. I should be able to disassemble and set everything to your needed specs in one day.
After that, It is up to Dave.
Hell, I just design these things. You would not wish me to do any body stuff. (I cannot even wax my own car.)
