Old 01-01-2004, 12:39 PM
blykins blykins is offline
Default Bellhousing Alignment Questions
1. Lakewood's tolerance is .005". Has anyone had trouble with their trannies with this little of a misalignment?
2. Would you recommend getting it closer?
3. If I weld the offset dowels on, could there be any problems with welding and the ignition box still in place and wired up? The car is not complete, so there is not a ground strap from the engine to the frame. If this would be a problem, would it be sufficient to ground the engine to the frame with a jumper cable...?
4. How many times have you had to use offset dowels with a Lakewood?
Answers do not necessarily have to be in that order....hehehe....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
