Old 01-01-2004, 04:02 PM
Steve Dickey Steve Dickey is offline
Craig,
You bet, I'll send you a pict.
Brent,
I thought about voiding the cert as well. I found it interesting that Lakewood sells the collars (and longer dowels) to be welded on to the bellhousing. I initially bought the offset dowels and played with them but could not dial everything in as well as I would like. It was kind of like chasing your tail. Using the weld on collars I gently snugged up on all the bolts and tapped the bellhousing flange with a hammer in the exact direction I wanted it to go and in a matter of minutes had it centered. Using the offset dowels I screwed around for about one or two hours and gave up. Let us know how things work out.
Steve
