Thread: T56 speedometer
Old 01-01-2004, 04:21 PM
48 IDA's Avatar
48 IDA 48 IDA is offline
Cobra Make, Engine: 1965 Contemporary 427 SC. built in 1982 before CCX serial #. has body #106. engine 351-C with 48 IDA'S 500 hp, T-56 6 speed, Halibrands k/os. Featured in KIT CAR, MOTOR SPORTS MONTHLY, AUTO X, AND SPORTS CAR. Original owner/builder
Default T-56 speedometer
Bill, I just went thru this with my conversion using the t-56.
The picture looks like you have a speed sensor for the speedometer. The too large cylinders that screw into the aluminum housings are reverse lockout solenoids. Looks like the speed sensor in located under the rear most lockout solenoid. I understand that all the oem trans have speed sensors. while all aftermarket have provisions for speedo gears.
www.atrol.com markets a cable x convertor, that uses your oem speed sensor, and converts the signal to a speedo cable connection for your speedometer. They may also be able to help with your VDO guages. Hope this helps.
Don
