Sounds like BC has the easy solution.
Brake and clutch pedal pads look like standard auto supply store variety (Help, etc.) of standard e-brake foot pedal pad replacements.
Throttle cable. Used standard Lokar street rod cable throttle with speed shop throttle cable - carb bracket.
A suggestion before installing the pedal assembly would be to use better bearings on the cluch pedal cross shaft, even re-working it for ball bearings. Mine are getting sloppy already.
