Thread: HELLO gsharapa
Old 01-02-2004, 09:56 PM
DC COBRA DC COBRA is offline
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
Gary, I ordered the motor from Keith himself. It suppose to be complete, dynoed ready to set in car. I am going to run an electric Mesiere water pump, Keith thinks there shouldn't be any cooling issues since using an aluminum block. Keith seems to think power will be in the 625 range, using the AFR 225 fully ported heads. The BDR car will support 3.19 gearing, weight around 2200 lbs. Traction will probably be an issue. What transmission do you use?Is the 638 HP rear wheel horsepower?
DON
