Old 01-03-2004, 10:23 AM
nanard289 nanard289 is offline
Cobra Make, Engine: Cobra Daytona (from USR) 302RDI Yates headed + Weber induction
Be careful Steve. if you want to install this bloc in your coupe, you will have a confict between the dry sump pump and the body. So you will need to cut (by 1") the motor brackets and to made a new lower dry sump pump support (to locate the pump axis just below the main body tube). This is possible because the dry sump pan is shorter than a wet oil pan. Then you have to install a dry sump tank as closed as possible. However if you accept to do it, the result can be interesting.
Bernard
