Old 01-03-2004, 11:04 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
blykins - Actually I strarted with a old Zoom set of street 410 gears then switched to the Richmond pros later. Pro gears are angle cut different than street gears also, and are actually stronger than stock gears, and noisier. And they wear out faster also, esp. on the street. For that reason I've allways had my pro street rear ends set up a little "loose" down through the years,,,,,,,,,,,,,,,,, Spools are another story. I think you will like your locker if it is set up right , but it could be a little stiff at first though. Depends on who and how it was set up. The only thing that I didn't like about my rear end was it really grabs hard on hard turns, when you pour the coal to it. Took me a while to get used to that. Straight line - it's the berrys.
cobrashock
Ron Shockley
