Old 01-04-2004, 09:17 AM
David Kee David Kee is offline
With 500 ftlb of torque being the most important feature you can forget any of the Tremec 5 speeds. The one that would come the closest to handling the power would be the TKO II. Also if you are looking for quick accelleration the 5 speed tremec ratios (1st @ 3.27 and 2nd @ 1.98) are not going to help. If you change the rear gear to make 1st useable the drop in rpm when you shift to second is going to be a killer.
