Old 01-04-2004, 12:15 PM
Rick Parker's Avatar
If it won't budge after gripping it with some vise grips, stop before it shears and soak it with Liquid Wrench, then use propane torch to heat tranny around the stud, then hit it on the end and it should be able to be removed, just try not to shear it off, because then you have an entirely different situation to deal with. If there is enough thread, use two jamb nuts and an end wrench for leverage........just do not shear it off. Run a tap in it afterwards.
Rick
Rick
