Old 01-06-2004, 11:38 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Arrow
Mike,
I have .020 flat tops so if all I change is the heads, the only thing would be the static compression ratio change?
I also run a comp cams 280 H street cam, it has .530 lift and 230* duration @ .050 . Would that have enough duration to work with the high compression heads?
Perry.
