Old 01-07-2004, 05:00 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Talking
Factory Five Racing COUPE  Professionally built 306 cubic inch<br /> engine with twin turbos feed through a Mid Shifted Tremic TKO
Factory Five Racing
Daytona
Coupe
FFR# 2199CP
Painted Electron Blue Metallic with
Polar White stripes
$45,000 obo
cubic inch engine with twin turbos feed through a Mid Shifted Tremec TKO
transmission (with 35th Anniversary shifter knob) attached to the engine by a Lakewood
scattershield and Ram Power grip Clutch, next to the fully independent coil
sprung rear end. The
top quality of this car starts with the DSS 306 Pro Bullet short block with the
optional stud girdle and windage tray and a Comp Cams "Turbo"
camshaft, Melling hi volume oil pump, and a hi capacity Speedway hi capacity oil
pan.
The Edelbrock Victor Junior heads were assembled with chromemolly, hardened push
rods and Crane 1.6 roller rockers, while the intake manifold is a matched Edelbrock
Victor 5.0 unit. Rounding the top of the engine out is a 75mm throttle
body, 42lbs/hr injectors, and  Incon Systems Turbos and Intercooler setup,
finally a
MSD 6BTM ignition.
Other attention to details are Polyurethane Mounts for both the engine and
transmission, along with Aeromotive 500 lbs./hr fuel pump, Aeromotive Fuel Pressure
Regulator, Aeromotive 3/8" sending and 5/16" return lines leading to and from
the 15 gallon Fuel Safe racing gas tank (equipped with foam and safety bladder).
Brakes are another area where this cars engineering and attention to detail
really shine, on the front of the car you have a combination of custom valved
coilovers, Stainless Steel
Brake Corps slotted front rotors coupled with Wilwood 6 piston calipers, a
Wilwood proportioning valve, Stainless braided brake lines. Other items worth
mentioning are the entire exhaust system which is ceramic coated, a Torsen Rear
locking differential,  Autometer Ultra-lite gauges with a shift light, and
a Kirkey Intermediate road racing seats, removable 14" leather steering
wheel, powder coated frame Spec Racer valved coil over shocks, and the Cobra
"R" wheels
(17"x 9"
with 275/40R17 tires on the front, and 17"x 10.5" with 315/35R17 on the rear ).
This same car has been used in the Factory Five showroom, along with being the
Carlisle and SEMA show car at the Factory Five booth in 2001. To duplicate this
car today would cost you $60,000.
Click here
to contact the seller.
