Pat, I was actually going to suggest the very same thing. I have a collapsed front line on one of my sleds, and sadly know the symptoms well--need to fix it actually as I have locked a wheel in front of my house while practicing late braking (something I know you can understand if you are as ill as I am). If it is truly a front/rear bias issue, are there just front/rear feeder lines before they split off to right and left front or rear. Maybe check those? Anyway to test for even front/rear lockup versus just one corner wheel lock before the others?
